400-470Mhz. Monofon, laddare och extra batteri medföljer. Längre antenn med bättre mottagning kan medfölja för 100kr extra.
![Bild](http://i122.photobucket.com/albums/o248/Elajten/Mobile%20Uploads/9AA9C06F-0D25-4E3B-9441-19483FF6811E_zpsdhks7fzb.jpg)
Info:
1. UHF
2. 400Mhz-470Mhz
3.UHF 4W output power
4.128 memory channels
5.Built-in 50 CTCSS and 104 DCS
6.Wide (25kHz) and Narrow(12.5kHz) channel spacing programmable in separate channels
7.Come with 1200mAh Li-ion battery
8.Input Frequency directly by keypad
9.VOX built-in
10.Frequency Scan & CTCSS Scan
11.Three different scan type: TO/CO/SE
12.Three color LCD backlight display
13.Sound Alarm
14.Programmable by PC software
16.Priority Scan Function
17.Adjust power High/Low
18.Switching between Channel/VFO
19.Display Channel+ Frequency mode.
20.Adjust squelch level (0-9)
21.Busy channel lockout
22.Keypad lock
23.Reverse Frequency Function
24.Channel step 5k,10k,6.25k,12.5k,25k
25.Program alphanumeric channels name
26.Self-program
