u4gm Arc Raiders OP Perk Nerf Update
Alam560
If you were part of the Arc Raiders closed alpha, you probably ran into the same problem as everyone else – getting dropped in one hit by a sniper or blown apart by a grenade launcher that felt way too strong. The reason? A single perk called Diamond Tip. It looked harmless at first, just a 30% damage boost on the last bullet in your mag. But players quickly figured out how to make ARC Raiders Items work in their favour by turning every shot into that “last bullet.”
The trick was simple but nasty. If you had a single-shot weapon, like certain grenade launchers, every round automatically got the bonus. For high-powered snipers, people would fire one shot, instantly reload, and repeat. The game thought each shot was the final one, so the perk stayed active all the time. It didn’t matter what other perks you had – this one overshadowed everything else. Matches started feeling predictable, with the same loadouts dominating and very little room for variety.
Embark Studios stepped in before the problem could carry over into the full release. The fix they rolled out is pretty smart. Now, Diamond Tip only works if your weapon’s magazine holds at least five rounds. This kills the exploit for single-shot guns completely. And for snipers, the reload trick no longer works, since the perk won’t trigger unless you’re actually down to your last few bullets in a bigger mag. It’s a clean change that doesn’t mess with the perk’s original idea – rewarding players who can manage ammo well – but shuts down the cheesy tactics.
For players, this means we’re back to exploring different builds instead of everyone chasing the same overpowered setup. You’ll need to think more about your weapon choice, your perk synergy, and how you approach fights. It’s a shift toward balanced gameplay, where skill matters more than exploiting a loophole. And honestly, that’s what you want from a game still in testing – devs paying attention, making bold changes, and keeping things fresh.
While the wild days of the old Diamond Tip are gone, the nerf opens the door for more creative strategies and fairer fights. If this is how Embark handles balance, Arc Raiders has a solid future ahead. And if you’re getting ready for the next round of testing, it might be time to rethink your loadout and maybe even cheap ARC Raiders Items to prep for whatever meta comes next.
