Arc Raiders Stamina Guide: Tips and Tricks from Experienced Players
WhisperFlower
Arc Raiders is a game where survival and efficiency matter more than flashy moves. Many new players ask about items, stamina management, and ways to optimize gameplay. In this guide, I’ll explain how some commonly found items work in practice and answer questions most players have when they first start.
What is the Bloated Tuna Can and Should I Use It?
The Bloated Tuna Can is a common trinket you can find in residential or commercial areas. Most players notice it immediately because of its unusual description: “Something tells you that you don't want to open this…” This is mostly flavor text, but it does hint at the fact that the item isn’t particularly exciting.
In practical terms, the Bloated Tuna Can restores a small amount of stamina—25 points to be exact—and takes about 1 second to consume. For context, stamina is important for sprinting, dodging, and using certain abilities. Most players only use this item when they are in a pinch, as it doesn’t restore much compared to other consumables.
The can is light, weighing only 0.2kg, so you don’t have to worry about carrying it affecting your inventory. Its in-game value is $1000, which is minimal but can be helpful if you’re selling low-priority loot to make room for better gear.
Where Do Players Usually Find the Bloated Tuna Can?
In general, players find this item in residential and commercial areas. These locations are common early-game zones where you’ll be scavenging for supplies. Most players recommend checking every building carefully because the spawn rate is 1 in 15, meaning you won’t see a Bloated Tuna Can every time you search the same area.
Residential zones tend to yield more food-type items like the tuna can, whereas commercial zones often have a mix of consumables and crafting materials. Most players who are farming for stamina items focus on residential zones first and then clear commercial areas if they need more variety.
How Do Players Usually Manage Stamina in Arc Raiders?
Stamina management is crucial, and in practice, players don’t rely heavily on Bloated Tuna Cans alone. Because it restores only 25 points, it’s mostly used as a temporary buffer rather than a full solution.
In general, players combine several strategies:
Pacing movement – Avoid running constantly. Sprint only when necessary.
Consumable rotation – Keep a mix of items that restore stamina in different amounts. The Bloated Tuna Can is usually a backup.
Team coordination – In multiplayer, letting teammates handle tougher fights while you recover can prevent wasteful stamina use.
By using the Bloated Tuna Can strategically, most players can extend their exploration without having to return to a safe zone too frequently.
Should I Sell or Keep the Bloated Tuna Can?
Most players treat this item as a low-priority consumable. If your inventory is full and you find a better stamina item or a rare blueprint, selling the tuna can is fine—it’s cheap but can add up over time. However, in practice, keeping a few for emergencies is recommended.
The general rule among experienced players is to carry 2–3 in case you need a quick stamina boost during a mission. Using it randomly is usually inefficient, but keeping it for moments when you can’t retreat is smart.
How Players Find and Use Blueprints Efficiently
Blueprints are key to progressing in Arc Raiders, and many new players ask where to get them fast. In general, the game drops blueprints in loot zones, but sometimes it takes longer to collect specific items. Some players also look for online offers to buy ARC Raiders blueprints fast delivery on U4N, especially when they want to upgrade their gear without spending hours farming.
In practice, it’s important to balance between farming in-game and using fast delivery options. Most players recommend focusing on gameplay first—collect what you can naturally—and then consider additional sources only if you’re aiming to save time.
Tips from Experienced Players
Inventory management – Keep your backpack balanced between consumables, blueprints, and mission-critical items. Overloading on low-value items like tuna cans can slow you down.
Loot smartly – Focus on areas that drop the materials you need the most. Residential zones are good for stamina items; commercial zones are better for gear upgrades.
Use items strategically – Don’t consume small stamina items immediately. Save them for moments when you’re about to engage or escape.
Know your spawn rates – Items like the Bloated Tuna Can appear infrequently (1/15 in certain zones). Don’t waste time farming one type of loot exclusively.
Coordinate with teammates – Arc Raiders is easier when each player carries specific consumables instead of everyone hoarding the same items.
In general, Arc Raiders rewards careful planning and resource management over fast reactions. Items like the Bloated Tuna Can are minor but can be helpful when used wisely. Experienced players focus on knowing where items spawn, how much they restore, and when to use them. By combining good stamina management, smart inventory use, and efficient blueprint collection, you can make progress without frustration.
