Everything Players Need to Know About Arc Raiders Flame Spray
Postat: lör 17 jan 2026, 03:30
av WhisperFlower
If you’re playing Arc Raiders, you’ve probably come across the Flame Spray gadget and wondered how it actually works in practice. In this guide, I’ll break down what most players need to know about using, crafting, and maintaining it, based on common in-game experiences.
What Is Flame Spray and How Does It Work?
The Flame Spray is a quick-use gadget in Arc Raiders that lets you spray fire in the direction you’re aiming. It deals 10 damage per second, which is decent for clearing small enemies or interrupting groups in close quarters. Most players use it as a crowd control tool rather than a primary damage source.
Its behavior is straightforward: point it at your target, hold the fire button, and the flames will continue until the gadget runs out of fuel or is interrupted. In general, the flames don’t have a long reach, so you need to get fairly close to your enemies to be effective.
How Do You Craft Flame Spray?
Unlike many items in Arc Raiders that you can unlock in the workshop, Flame Spray must be crafted in-round. This means you can’t prepare it ahead of time between missions; you have to craft it during the mission itself.
Most players find the in-round crafting process simple once they gather the right components. You need:
1× Air Freshener
1× Fireball Burner
You also need the In-Round Crafting skill unlocked. Once you have these, crafting the Flame Spray is usually quick and doesn’t take more than a few seconds.
Players often scavenge multiple Fireball Burners in early rounds to make sure they can craft or repair Flame Sprays as needed.
How Do You Maintain and Repair It?
Durability matters if you plan to rely on Flame Spray for longer encounters. Repairing requires:
1× Canister
1× Fireball Burner
This combination restores 50 durability points, which is usually enough for a few more uses. In practice, most players cycle between using the gadget and repairing it, especially when scavenging for parts is easy in your mission.
If your Flame Spray breaks, you can also recycle it to get back some of the materials—1 Canister and 1 Fireball Burner—which is useful if you’re low on resources.
What Are the Best Situations to Use Flame Spray?
From player experience, Flame Spray is most effective in close-range fights, especially when dealing with clusters of weaker enemies. Since the flames don’t reach far, it’s not ideal for sniping or long-range engagements.
Many players combine it with other gadgets or weapons. For example:
Starting an encounter: Use the Flame Spray to disrupt enemy groups before switching to a primary weapon.
Defensive situations: Spray fire around choke points to control enemy movement.
Team support: In multiplayer matches, teammates can focus on single targets while you suppress groups with flames.
In general, Flame Spray is seen as situational but versatile if used wisely.
Can You Buy or Acquire Blueprints Quickly?
Some players look for ways to get gadgets faster without waiting for in-round crafting. In the community, there’s often discussion about ways to buy ARC Raiders blueprints fast delivery on U4N. While this is not part of normal gameplay mechanics, it reflects the demand for speeding up access to gadgets like Flame Spray. In practice, most players still rely on scavenging and in-round crafting as their main source.
Common Mistakes to Avoid
From experience, here are some mistakes new players make with Flame Spray:
Using it at long range – the flames don’t travel far, so you’ll miss most enemies.
Ignoring durability – running out mid-fight can leave you without your gadget.
Crafting too late – since it can only be crafted in-round, waiting too long may mean missing your chance during a critical wave.
Wasting components – stockpiling too many Flame Sprays without considering repair options can drain resources unnecessarily.
Most players who avoid these mistakes find the gadget much more reliable.
The Flame Spray in Arc Raiders is a handy, close-range gadget that can disrupt enemy groups and provide tactical control during missions. It requires in-round crafting using an Air Freshener and Fireball Burner, and keeping it maintained requires paying attention to durability. While not a primary weapon, it complements most loadouts well if used strategically.
By understanding how and when to use it, and by avoiding common mistakes, most players can make the Flame Spray a consistent part of their arsenal.
Enemy Weaknesses: Arc Raiders Smoke Grenade Trap
