CAESAR II 14 download
https://crackeddownload.com/product/cae ... -download/
CAESAR II 14 full crack download CAESAR II is the industry standard for pipe stress analysis, letting you build, assess and report on piping systems of any size or complexity in accordance with more than 35 international piping code standards and many environmental and equipment guidelines
CAESAR II 14 What’s New in Caesar II-Version 14?
Hexagon has released their new version of stress analysis software, Caesar II Version 14 recently. The latest software version has truly extended its capabilities by incorporating many changes based on user feedback from the Caesar II user community. The much-awaited Hydrogen piping and pipeline code (ASME B31.12) is included in Version 14 of Caesar II software. In this article, we will highlight some of the new capabilities that you will find when you install Caesar II Version 14 on your PC/laptop. So, let’s start with the changes in codes and standards.
CAESAR II is the industry leader in the pipe stress analysis software domain. It allows users to build, analyze, assess, and report on piping systems of any size or complexity. Whether you’re dealing with weight, pressure, thermal effects, seismic conditions, or other static and dynamic loads, CAESAR II helps engineers confidently analyze piping systems. It is owned by Hexagon.
Hexagon has come up with their most-awaited update of the software Caesar II version 14. It has been released recently. Similar to earlier releases, this version of the software comes up with many updates that will make the life of pipe stress engineers easier. The most significant change is the inclusion of ASME B31.12, Hydrogen Piping and Pipeline code in their database. Additionally, they have updated most of the codes with the latest available code editions. Just to give an example, Pipe Stress Engineers will be able to use ASME B31.3-2022 in Caesar II-14. Similarly, Caesar II version 14 is enriched with the latest editions of ASME B31.4, ASME B31.8, ASME B31.1, and many other codes. Some of the significant changes are already mentioned in the following blog post, “What’s New in Caesar II-Version 14?“
Even though most of the major changes are already highlighted in the above blog post, still you may have some doubts and wish to get an option to listen directly from the software owner. That is why Hexagon has arranged a free webinar to explain all the changes they have incorporated in their latest release of Caesar II-Ver 14.
