Torrent download ExactFlat 1.7.0 For Rhino Paradigm Geolog 2024 PSSE 36.3.1 Polar Instruments SI9000 v24
Maptek vulcan 2026 EFI Fiery XF 9.0
-----gotodown#list.ru-----
Just for a test,anything you need-----
Synopsys VC_static vY-2026.03 aarch64
Synopsys Impl vY-2026.03 Linux64
Coreform Cubit (ex. csimsoft Trelis) 2026.8
Golden Software Grapher 27.1.296
Mater Dei Engenharia SteelX Industrial for Autodesk Advance Steel v1.5
BimStep Architecture, BIM, General, MEP, Holes for Autodesk Revit 2027
ESI.AquiferWin32.Modelling.Professional.v6.0
PSCAD v5.0.0 and Initializer
Synopsys VC Static vY-2026.03 Linux64
ESI.Groundwater.Vistas.Premium.v9.22.5
TIA Portal STEP7 Safety WinCC v21
Datamine (ex. Encom) Discover 2024 v23.0.426
Exelis (ex. ITT) ENVI v6.3
SoftLogix 5800 v19.0
Studio 5000 logix emulate 32.00.00 Win32
AVL.Simulation.Suite.R2026.1.1.Linux64
Design Master Software ElectroBIM v2.3.1.2 for Autodesk Revit 2027
GreenValley Suite v9.1 Build 20260720
Vectric Aspire Pro 12.509 Win64
PTC Creo 13.4.1.0 Win64
CM.Labs.Vortex.Studio.2026.6.0.40
Rockwell Software RSLogix 500 v12.00.00
RSLinx Lite 4.13.00 (CPR 9 SR 13.0) Win32
Qbitec v1.8.1. for Autodesk Revit 2027
Trimble.Tekla.Structures.2026.SP4
Exelis (ex. ITT) .GeoSpatial.SAR.Essential.v1.1.0.Build.20.10.2025.Win64
Exelis (ex. ITT) .GeoSpatial.Sarscape.v6.3.1.Build.19.08.2026.Win64
Maplesoft Maple Flow 2026.1
Marshall Day Acoustics ZOBRA 3.0.4
Arm Socrates v1.801 Linux
AIST.PeakLab.v2.01.00
Ametek.Land.Image.Pro.2026.V2.5.1.Win64
Dlubal SHAPE-MASSIVE 6.90.01
Luceda.Photonics.IPKISS.Design.Suite.2026.06.Win64
LucidShape 2024.09
Pepakura Designer 6.3.4
Synopsys CODEV 2025.03 Win64
NV5 Geospatial Solutions (ex. Exelis, ex. ITT) ENVI, IDL, LiDAR, SARscape, Opticalcape v6.3
DELMIA V5-6R2023 v5R33 SP4 Win64
Leica Hexagon HxMap v5.0.0 build 49982
Simcore Processing Modflow v11.0.7 Win64
AIST Software PeakLab v2.01.00
Ametek.Land.Image.Pro.2026.v2.5.1 Win64
Plexim.PLECS.2026.v5.0.6.Win64
Cadence SPECTRE 25.10 ISR9 v25.10.09.367 Hotfix Linux
Cadence System for Testing PDK (STEP) Release v01.05.003 Linux
Cadence Virtuoso Studio IC25.1 ISR6 v25.10.060 Hotfix Linux
Empyrean ALPS GUI 2026.06 Win64
AnyLogic Pro 8.9.9 Multilingual Win64
CTC Software BIM Suites 2027 for Autodesk Revit 2027
Empyrean ALPS 2026.06 Win64
Empyrean iWave 2026.06 Win32_64
Zeataline Projects PipeData-PRO 15.0.03_Protable
Autodesk Inventor Professional 2027.1 Win64
Tekla Structures 2026 SP3 Multilingual + Environments Win64
Nucleomatica iNMR v 7.2.3
Nucleomatica.iNMR.v7.2.3.MacOS.UB
Parallel Graphics Cortona3D RapidAuthor 2606 Win64
ProfiCAD 14.0.0
Approximatrix.Simply.Fortran.v3.41.4438
AVL.Simulation.Suite.R2026.1.1.Win64
DESWIK.GO.2026.1.2110.Win64
MagiCAD.2026.UR2.for.Autodesk.Revit
Mater.Dei.Engenharia.SteelX.Industrial.for.Autodesk.Advance.Steel.2027
PHASER.Engineering.Suite.(ES).v1.0.13
C3D Labs CADEX CAD Exchanger 3.24.20
Ellis.PaleoScan.2025.1.1
Synopsys RTL Arch vV-2023.12-SP5 Linux
Intergraph CADWorx Pro (Plant, P&ID, Equipment, IP, SpecEditor) v24.00.00.1088
Luxion.KeyShot.Enterprise.2026.2.1.Win64
Dassault.Systemes.GEOVIA.MineSched.2026.R1.v9.11.26673.1
ETGeoTools v11.5
ETGeoWizards v12.9
ETSurface v7.5
Precisely.MapInfo.Pro.2023.2.244
ESRI ArcGIS Documentation Center 2026.1
Finite Element Analysis LUSAS Academic v19.0-2c1.repack
Dassault Systemes GEOVIA MineSched_2026_Refresh1 Win64
Dassault Systemes GEOVIA Surpac 2026 v7.9.41892 Win64
CYDAREX.CYDAR.v8.3.7.5
ESRI ArcGIS Drone2Map v2026.1.1901
ESRI ArcGIS Reality Studio v2026.1.1904
Mater Dei Engenharia SteelX Industrial for Autodesk Advance Steel 2027
MedCalc 23.6.2 Win32_64
Graebert ARES Electrical CAD 2027 SP1 Win64
nTopology 5.50.2
ZwSoft ZW3D WuKong 2027 Mulilingual Win64
DiRootsOne 0.10.0 for AutoCAD 2026 and AutoCAD 2027
Nucleomatica iNMR 7.2.0
Synopsys Hspice vY-2026.03 Win
Thunderhead.Pathfinder.2026.1.211
TrainController Gold 11.0 A1
Trimble.Tekla.Structural.Design.Suite.2026.SP2
Synopsys Custom WaveView vY-2026.03 Win
Trancite AutoScene Draw 26.0.0.38477
Trancite Easy Street Draw 8.1.6.36458
Trancite FireScene 8.1.6.36461
Trancite ScenePD 8.1.6.36462
WORKNC 2026.2.2625 Win64
ESRI ArcGIS Pro v3.7.1
3dmine plus v2025
- download01
- Över 5000 inlägg!
