People aren't exactly bragging about the nastiest Mirage 3.28 tech right now. You'll see vague clips, half a PoB, then silence. The idea is simple: if it stays quiet, it might stay alive. If you're trying to put the pieces together without burning a week flipping items, some folks just grab low price POE 1 Currency and move on, because the market around this setup has been getting silly.
Why recovery rate suddenly matters
Most of us learned to live with leech caps. Leech feels good, then it hits that ceiling and you're back to respecting degens and chip damage. Mirage quietly pushed a different lever: life recovery rate. A couple of nearby passive clusters (especially around the Templar and Marauder side) now make "recover X% of life per second" scale harder than it used to. With a real life stacker pool, it stops looking like normal sustain and starts looking like a mistake. You don't need a spreadsheet to feel it either. You take a hit, the globe drops, then it just climbs like a lift with no brakes.
The Inquisitor angle people keep hinting at
The popular version is a Life-Stacker Arc Inquisitor, and yeah, it sounds backwards at first. Caster? Stack life? But Energy Shield has that recharge delay, and in actual fights that delay is a tax you pay over and over. Inquisitor gets to play a different game. With Pious Path and Consecrated Ground, you're getting a chunky percentage of your life back every second just for existing in the right spot. If you're sitting around 10k life, the baseline regen is already big, and once recovery rate multipliers kick in, it ramps fast. The funny part is watching Uber mechanics that normally "teach" you to move. You still move, sure. But you notice you don't have to panic the same way.
Gear costs, trade pain, and the real risk
This isn't a comfy league starter unless you get lucky. The damage and the life total both want very specific pieces, and the usual suspects have been getting bought out: Replica Alberon's Warpath, high-roll Astramentis, and anything that helps you squeeze more attributes or flat life without gutting damage. That's why the build feels "hidden" in practice—half the player base can't justify the price, and the other half doesn't want GGG noticing a character that can stand in ugly arenas and heal through the mess. It's not immortal, though. Big one-shots still delete you, and some Uber slams don't care how pretty your regen looks on paper.
Getting it online before it changes
If you want to try it, you do it sooner rather than later. These kinds of scaling loops don't usually survive untouched, especially when they let you shrug off sustained boss damage and ignore the usual attrition. If you're short on time and just want to actually play the build instead of living in trade chat, buying currency or key items through U4GM is the straightforward option, since it cuts out a lot of the grind and lets you focus on mapping, crafting, and boss attempts while Mirage is still in this state.
U4GM Guide POE 3.28 Mirage Infinite Regen Inquisitor Build
- CosmicFlare
