In Arc Raiders, Moss is far more than a unremarkable plant-it's a critical resource that can turn the tide of a raid, keep you alive in tight spots, and unlock essential crafting recipes. Whether you're gearing up to make a defibrillator for your squad or need a quick health boost, knowing how to find and farm Moss efficiently is key to success. This guide breaks down every method to get Moss, from easy trader purchases to high-yield farming spots, so you can stock up without wasting time.
Why Moss Matters: What It's Used For
Before diving into where to find Moss, it's important to understand why this resource is worth your time. Moss serves three vital purposes in Arc Raiders, making it a must-have for both solo players and squads.
First, it acts as an emergency health item. When consumed directly, Moss restores 1 HP per second for 10 seconds-not a massive boost, but enough to survive a close call when you're out of bandages or sterilized kits. This small health bump can mean the difference between escaping a fight and respawning.
Second, Moss is a core ingredient for crafting defibrillators, one of the most powerful tools in the game. Defibrillators let you instantly revive downed teammates, a game-changer in PvP matches and difficult PvE missions where every squad member counts. You'll need 1 Moss plus 9 Plastic Parts to craft one, so a steady supply is non-negotiable.
Finally, Moss can be recycled for Assorted Seeds, which are essential for upgrading Scrappy, your rooster companion, and for purchasing more Moss from traders. It even sells for 500 coins if you're short on in-game currency, adding another layer of utility.
Method 1: Buy Moss from Celeste (The Easiest Way)
If you're short on time or don't want to venture into dangerous areas, purchasing Moss from Celeste-the in-game trader-is your best bet. This method requires no combat and guarantees a steady supply, as long as you have the right currency.
To buy Moss from Celeste, head to the Traders tab in the game menu and select her profile. She stocks up to 5 Moss at a time, with each piece costing 10 Assorted Seeds. This means you can buy all 5 for 50 Assorted Seeds, a small price for the convenience.
The best part? Celeste's inventory resets every day, so you can return daily to buy 5 more Moss. If you're low on Assorted Seeds, you can recycle extra Moss or other nature materials to stock up, creating a simple cycle to keep your Moss supply consistent.
Method 2: Farm Moss in the Wild (High-Yield Locations)
For players who prefer to scavenge and farm, Arc Raiders has several maps with reliable Moss spawns. Moss is a nature material, so it only appears in areas marked with the nature icon-but some spots are far more productive than others. Below are the best farming locations, organized by map.
Dam Battlegrounds: The Top Moss Farming Spot
Dam Battlegrounds is widely regarded as the best map for farming Moss, thanks to its concentrated spawn points and low enemy density in key areas. The Hydroponic Dome Complex is the star here-this area is filled with cylindrical grow beds, wicker baskets, and glass domes that regularly spawn Moss.
A systematic run through the Hydroponic Dome Complex can yield 5–10 Moss in under 5 minutes. Focus on checking the cylindrical containers and baskets inside the domes; each often holds 1–2 pieces of Moss. You can also check nearby areas like the Scrap Yard, Small Creek, and Old Battlegrounds for extra spawns.
For even more Moss, visit during the Lush Bloom map event. This event increases Moss spawn rates in the Hydroponic Dome Complex, making it easy to stock up in one run. Additionally, the Formicai Hills area is a secluded alternative-fewer players venture here, so you can farm in peace.
I had questions about my ARC Raiders BluePrints order and they fully answered them and were friendly, helpful and courteous. I 100% recommend MMOEXP.com and their customer service team!
