ARC Raiders Key Investments Before the Expedition Reset With U4N
Postat: tis 01 sep 2026, 09:37
av JackWalker
With the September 8, 2026 Expedition Window approaching, players have a limited amount of time to decide how they want to prepare for a possible character reset. One area that deserves more attention than it usually gets is the value of locked-room keys and the loot they can produce. For anyone still working on ARC Raiders BluePrints, this period is especially important because a good raid can improve both immediate stash value and long-term progression.
The right approach is not simply to empty your stash or use every key without a plan. ARC Raiders BluePrints can be difficult to obtain consistently, and some locked rooms have become considerably more attractive after recent updates. Knowing which keys deserve priority can help you make better use of your remaining raids before the Expedition decision.
Stop Hoarding and Start Converting Value
As the reset approaches, keeping every item you find is less useful than it was earlier in the character's progression. Permanent coins and overall stash value are important when determining your Expedition rewards, so unused equipment should be reviewed honestly.
Extra weapons, duplicate consumables, and valuable trinkets can often be sold instead of taking up storage space. Golden horse statues and similar valuable items are particularly useful when you are trying to move toward the next value threshold.
Keys are different. Their vendor prices do not reflect what they can actually produce. Selling an expensive key for a relatively small amount of currency may be a poor decision when the room behind it can contain high-tier weapons or valuable blueprints.
Which Locked Rooms Deserve Priority
The current loot balance makes several locations stand out.
Raider Hatch Keys are among the most useful options because they can provide access to valuable loot while offering extraction routes that may be quieter than the most obvious areas. For players who prefer reducing unnecessary PvP risk, that flexibility matters.
The Buried City Town Hall Key and Dam Control Tower Key are also strong investments. Their locked areas offer reliable economic value, making them good choices when your main objective is increasing the overall value of your stash before the reset.
These keys should generally be used before lower-value alternatives, especially if you already have them sitting unused in your inventory.
Blueprint-Focused Keys Still Matter
Not every raid needs to be about maximizing coin value. If your character still has important blueprint gaps, locations such as the Buried City Residential Master area, Hospital, and JKV Employee Access deserve attention.
These locations contain dense collections of containers, giving you more opportunities to find structural or attachment blueprints. That can make an otherwise average raid worthwhile.
This is also where your personal progression should influence your decisions. A player who already has most desired blueprints may prefer economic routes, while someone with several important recipes still missing can get more value from blueprint-heavy locked rooms.
Do Not Gamble on Old Exploits
Some older methods of entering locked rooms without the appropriate key are no longer worth attempting. Developers have addressed window-clipping exploits and introduced punishment for players trying to bypass the intended access system.
There is little reason to take that risk when legitimate keys already offer strong rewards. A failed exploit attempt can turn a profitable preparation raid into a complete loss.
If you do not have the required key, simply move to another location. Efficient preparation is about consistency rather than forcing access to one particular room.
Watch Your Expedition Threshold
The three-million-coin target is another important part of preparation. For Expedition 2, the bonus skill-point progression is based on combined coin and stash value, with roughly 600,000 value corresponding to each additional point and five points available by reaching approximately 3,000,000 total value.
That creates an easy rule for the final preparation period. If you are already within roughly 200,000 to 300,000 of your next milestone, it can make sense to push for it.
Free Loadouts are useful for this kind of farming. Rather than risking your best equipment, take inexpensive gear into areas with dense containers. Stella Montis Assembly Workshop and Spaceport Security Lockers can provide opportunities to find useful weapons and other valuable loot without putting your most expensive equipment on the line.
When Skipping the Reset Is Reasonable
Not every character needs to enter the Expedition Window.
If you are far away from the next skill-point threshold and still have substantial blueprint or workshop progression remaining, keeping the current character may be more valuable. You would miss the benefits associated with another Expedition cycle, including experience, repair, and Scrappy material bonuses, but you would also preserve your existing local progression.
The decision should therefore be based on your actual position rather than the assumption that every reset is automatically beneficial.
Secure What You Cannot Replace
Before making the final decision, review your most valuable blueprints and equipment carefully. Ermal, the Nomadic Envoy, provides Expedition Vault slots that allow selected items to survive the reset. These slots are expensive, so they should be reserved for things that would genuinely hurt to lose.
The goal is not to preserve an entire stash. It is to preserve the items that will make your next character stronger from the beginning.
If you still need additional gear or useful materials before the reset, checking reliable options for ARC Items for sale can also help you prepare without wasting the final days of the window.
