How to Get Requisition Slips Fast in Helldivers 2
Postat: fre 19 dec 2025, 03:54
av FrostStrikeX
What Are Requisition Slips and Why Do You Need Them?
So, first off, what exactly are Requisition Slips? They’re basically in-game currency that you can trade for higher-tier equipment, including special weapons, armor, and other upgrades. The more slips you have, the more flexibility you get in customizing your loadouts for tough missions. Personally, I’ve found that having a healthy stash of slips really reduces the stress in higher-level missions—you can experiment without worrying about losing your progress.
Can Missions Give Me Requisition Slips?
Absolutely. Some missions are better than others for collecting slips. Missions with a lot of objectives or optional side tasks tend to drop more. A good tip is to replay missions that have “high loot” ratings because the game rewards you with slips more consistently there. Completing all secondary objectives often gives a bonus, and this can stack up over multiple runs. Don’t overlook those small mission tasks—they may feel tedious, but they add up faster than you think.
Are There Any In-Game Purchases That Can Help?
Yes, if you’re looking for a shortcut, you can buy Helldivers 2 medals from legitimate sources. These medals often come with Requisition Slips or can be used to unlock them faster. I usually recommend saving up your medals from regular missions and then using them strategically to unlock high-value items rather than spending them all at once. It keeps your progress steady without relying entirely on purchases.
What About Farming or Grinding?
Farming is definitely an option. Certain enemies and events drop Requisition Slips more often, and repeatable missions are a goldmine if you know which ones to target. A personal trick I’ve found effective is teaming up with friends or joining public groups for repeatable missions. The faster completion time per run usually means you get slips more efficiently. Plus, playing with a team makes the grind way more fun and less monotonous.
Can I Use External Services for Resources?
Some players use services like U4GM to get resources faster. I won’t go into too much detail here, but if you consider this route, make sure it’s a safe and trustworthy service. Many players use it to quickly acquire specific items without grinding endlessly. Personally, I see it as an option for those who want to skip some of the repetitive work, but I still enjoy doing some missions manually—it feels more rewarding.
Are There Ways to Get Cheap Items While Farming Slips?
Yes, you can sometimes find cheap Helldivers 2 items that help boost your slip collection. For example, consumables that increase mission rewards or temporary boosts to loot drops are worth keeping an eye on. Using them strategically during repeatable missions can significantly speed up your Requisition Slip gain. I like to stock up on these items whenever they’re available, because a small investment early on saves a lot of time later.
Any Final Tips for Efficient Slip Farming?
Prioritize high-yield missions: Some missions are just better than others for slips. Focus your time there.
Complete all objectives: Even side tasks can add up over time.
Use boosts wisely: Items that increase rewards are worth it.
Play in teams: Faster mission completion and better slip efficiency.
Balance grinding and fun: Don’t burn out—part of the game is enjoying the missions themselves.
Getting Requisition Slips fast in Helldivers 2 is mostly about knowing where to focus your efforts, using your medals wisely, and taking advantage of boosts or safe external resources if necessary. With these strategies, you’ll quickly have the resources needed to experiment with new loadouts and tackle harder missions without constantly worrying about running out of slips.
Balance Changes Overview: Helldivers 2 Weapons Tier List After Patch September 2025
