Fråga om Astro Ext -91
Re: Fråga om Astro Ext -91
Tack! Ja när bilen har fått godkänt på bilprovningen så kommer jag summera bilköpet, och jag hoppas att det kommer stanna här omkring jag är nu..
Cheva Astro Ext -91
Saab 95 2,3l Etanol steg 2
Peugeot 205 Cti
Peugeot 205 Cti
Någon som har en smart och bra ide om hur man kommer in i lamporna på instrumentbrädan?? Verkar ganska bökigt..
Cheva Astro Ext -91
Peugeot 205 Cti
Peugeot 205 Cti
Den kommer nog få godkänt så fort dom bara ser den på Bilprovningen
Hittade detta på ett amerikanskt forum (har själv ingen erfarenhet av den årsmodellen, har bara ägt en -97:a):
Instrument lamps:
Remove the plastic trim piece UNDER the steering column.
Remove the plastic trim surround that is over the instrument cluster.
As you remove the surround piece, be careful with the light switches and
remote mirror switches (if you have that). They are mounted on the left side
of that plastic piece and the wires are pretty short. Old vans, like yours, will
have failing and/or weak plastic clamps holding the switches. If you man handle
it too much, the brittle plastic will break.
You'll have to tilt the steering wheel and/or place the gear selector into low to be
able to move stuff around.
Once you get that plastic out of the way, unscrew and remove the speedo/instrument cluster.
Be careful of stray static electricity which may short out instruments.
Pull the housing with it's clear plastic front OUT away from the dash. If you have an electronic
speedo, it will all pull straight out. If you have a mechanical speedo cable, I think it will
require you to disconnect that at the rear of the speedo. I don't know exactly how to do that.
Once that's all out, set it face down on a soft surface. Be careful that the trip Odometer
finger on the front isn't in a spot where it will break.
Härligt nu ska jag ge mej på det så fort som jag har möjlighet.. Ja jag önskade att alla bilprovnings gubbar va så att dom bara godkände så fort dom ser den..
Cheva Astro Ext -91
Peugeot 205 Cti
Peugeot 205 Cti
Nu så är Abs lampan kopplad
det va ju inte det roligaste jag gjort och bökat med att få ur skiten men jag lyckades och nu är den kopplad på bilbältes lampan som tänds och släcks vid start.. Så nu borde dom värsta sakerna vara gjorda.. Jag återkommer med info om vad Bilprovningen säger om bilen,vi får se när den rullar in hos dom..
Cheva Astro Ext -91
Peugeot 205 Cti
Peugeot 205 Cti
Gött!
Kommer ihåg när jag satt utanför Bilprovningen i en gammal BMW e36, kopplade lampan på samma sätt
..klassiskt fix när det gäller ABS och Airbag
plelle78 skrev:Nu så är Abs lampan koppladdet va ju inte det roligaste jag gjort och bökat med att få ur skiten men jag lyckades och nu är den kopplad på bilbältes lampan som tänds och släcks vid start.. Så nu borde dom värsta sakerna vara gjorda.. Jag återkommer med info om vad Bilprovningen säger om bilen,vi får se när den rullar in hos dom..
Slocknar din bälteslampa efter en stund?
Min lyser upp när jag slår på tändningen,
sen blinkar den tills jag har satt på mig bältet....
I min Dodge är det samma sak som i hans Astro, den lyser bara en kort stund vid uppstart, även fast det finns sensorer till varje bälteslås
Konstigt ...
Helt riktigt den tänds bara en liten stund och sedan slocknar så fint så..
siktar väl på Bilprovningen i nästa vecka så vi får se om allt är lugnt..
Cheva Astro Ext -91
Peugeot 205 Cti
Peugeot 205 Cti
Just ja.. Någon som vet vart man köper multirem billigt till astron.. Har inte kollat alls ännu men den slirar lite ibland??
Cheva Astro Ext -91
Peugeot 205 Cti
Peugeot 205 Cti
Skönt att din lampa funkar på så sätt.
Fungerande ABS lampa verkar dock inte vara lika viktigt på de äldre bilarna.
(Tror det hänger på besiktningsgubbe)
Syrrans Vojje -92 är besiktad utan ABS och har inte ens en fungerande lampa längre. (bortplockad av mig)
Remmen du har, slirar säkert,
den har garanterat torkat under sin tid den har varit ståendes.
Mekonomen, BDS och liknande ställen tar hem rem ifrån t.ex. Hansen Racing.
Så den kan du hitta lite varstans till olika priser.
Ebay är ju ett annat ställe att söka på om du inte har panik med att få den inom de närmaste dagarna.
Serpentinremmar hos Hansen Racing, 610:- kr oavsett om man har AC eller ej.
På ebay.com (för samma rem/storlek), cirka 140:- med frakten.
Avenger skrev:Serpentinremmar hos Hansen Racing, 610:- kr oavsett om man har AC eller ej.
*GILLAS*
Jocke var namnet
Astro Ext All Wheeldrive -91
Jeep Grand cherokee I6 -94 SÅLD
Jeep Grand cherokee 5,2 -94 SÅLD
Nice.. Det blir ju lätt Ebay då.. Nån som vet vad det heter så jag vet vad jag ska söka efter??
jag och namn på engelska synkar inte helt.
Cheva Astro Ext -91
Peugeot 205 Cti
Peugeot 205 Cti
Serpentinrem, driverem på engelska = serpentine belt, drive belt etc.. =)
Här finns en till 4.3 V6 med AC:
http://www.ebay.com/itm/4060990-Goodyea ... 6c&vxp=mtr" onclick="window.open(this.href);return false;
..140:- INKL. frakt till Sverige.
