Chevrolet TS Nyttiga tråd (Trans Sport)
Gds-kit för AC, erfarenheter
Är det någon som har erfarenhet av GDS-kiten för AC?
Re: Chevrolet TS Nyttiga tråd (Trans Sport)
Fungerar bra, enkelt och smidigt att fylla på. Dock ej provat på en Trans Sport, men principen är densamma (instruktionerna som medföljer).
Procedur för att programmera in en ny nyckel till startspärren:
These programming procedures are only good for USA built vehicles.
The first digit of your 17 digit VIN number must start with the number 1 or 4.
If your VIN number starts with a 2 or 3 or a letter these procedures WILL NOT WORK.
Can I program a new key myself if I have no working keys?
Yes, once you have had the new key cut by a Locksmith
or other qualified persons use the following instructions.
1. Insert new key into ignition cylinder and turn it to the ON position.
(As far as you can go without cranking engine)
The security light on the dash will illuminate and stay on for ten minutes.
When the security light goes out, you have one minute to start the next step.
2. Turn the ignition cylinder to OFF and then back to the ON position.
The security light on the dash will illuminate and stay on for ten more minutes.
3. Turn the ignition cylinder to OFF and then back to the ON position.
4. After the security light has gone off for the third time, turn key off and remove
from ignition. The key is now programmed and all other keys have been erased.
5. Insert key and start vehicle to test key.
Can I program a duplicate key for this vehicle?
1. Insert an existing programmed working key into the ignition cylinder.
2. Turn ignition to the ON position and back to OFF
3. Remove the existing key and within 10 seconds insert new key and
turn it to the ON positiion.
4. The security light will light up for 2 seconds to indicate successful
programming of the addtional key. Remove key from ignition.
Tack för denna tråd!
Uppdatering för nyckelprogrammeringsprocedurerna ovan. Den första proceduren är för när man inte har någon fungerande nyckel, och tar ca 30 minuter. Systemet kommer då att glömma tidigare inprogrammerade nycklar, och ta in den nya istället.
Den andra proceduren är för när man har en fungerande nyckel och vill lägga till en till.
