Murder Mystery 2 is a game that rewards both skill and strategy, and one of the most effective ways to level up quickly is by farming coins efficiently. Whether you’re looking to upgrade your inventory, unlock rare perks, or expand your collection, knowing the best coin farming routes can make a huge difference. Here’s a guide to help you maximize your earnings across the most popular maps.
1. Bank Map: The Classic Coin Grinder
The Bank map is arguably the best starting point for consistent coin farming. As an Innocent or Sheriff, your main focus should be on patrolling high-traffic areas like the lobby and vault corridors. Here’s a simple route to follow:
Start near the main entrance and quickly move toward the teller stations.
Circle around the vault area, making sure to grab coins that spawn near the counters.
Keep an eye on the central hallway, as this area tends to have a steady flow of dropped coins after player interactions.
This route is effective because coins often accumulate in these hotspots, especially if multiple games are played back-to-back.
2. Mansion Map: Quick Loops for Rapid Collection
Mansion offers a slightly different dynamic, with more hiding spots and longer hallways. For fast coin farming:
Begin at the main foyer and sweep through the living room.
Move toward the kitchen and dining area, paying attention to areas where players tend to drop items.
Loop back via the staircase and second-floor hallways, ensuring no coin spawn points are missed.
The key on Mansion is speed. The map is compact enough that a quick loop can yield a surprising amount of coins in just a few minutes.
3. School Map: High Coin Density Zones
School is a favorite among players looking to farm coins because of its multiple classrooms and hallways:
Start by checking the classrooms near the entrance for early coin spawns.
Sweep through the hallways, focusing on the cafeteria and library, which often hold a dense concentration of coins.
Finish your loop by moving toward the gym, which tends to accumulate coins after player engagements.
For players aiming to buy Murder Mystery 2 weapons or hunt for cheap Murder Mystery 2 items, this map offers a solid balance of coin yield and accessible spawn points.
4. Strategy Tips Across All Maps
Prioritize routes that allow you to cover multiple coin spawn points quickly. Efficiency is key.
Keep track of where other players are farming. Sometimes the best coins are in less-traveled areas.
Take advantage of dropped items during rounds. Coins often appear near high-action zones, making it easier to grab them without extra movement.
By consistently using these routes, you can build up a strong coin reserve and have the flexibility to buy Murder Mystery 2 weapons or acquire cheap Murder Mystery 2 items, enhancing your overall gameplay experience.
Best Routes for Coin Farming in Murder Mystery 2 Maps
Här kan du läsa och skriva begagnatguider för olika USA-bilar. Vi granskar alla guider som skrivs och ser vi att något inte stämmer eller behöver läggas till/korrigeras så gör vi detta i samråd med trådskaparen/författaren. Vill du lägga till en bild i guiden så ska denna först mejlas till oss, varav vi lägger upp den i en särskild mapp som är avsedd för begagnatguiderna.
Önskas hjälp om köpråd för en bil som inte finns med här? Starta i så fall en ny forumtråd i kategorin för just det bilmärket.
- FrostStrikeX
- Minivan
