How Vassal Networks Work in Ashes of Creation
EmberMango
Understanding Vassal Settlements in Ashes of Creation
In Ashes of Creation (AoC), settlement progression is central to shaping the game world. One key mechanic that players often ask about is vassal settlements. Understanding how vassalship works is crucial if you want to influence your region, participate in node sieges, or strategically plan your character’s role in the world. This guide explains vassal settlements in practical terms, based on current design plans and common player behaviors.
What is a Vassal Settlement?
A vassal settlement is essentially a node that is under the control of a higher-level node, often referred to as the parent or sovereign node. The purpose of vassalship is to regulate node progression and prevent every settlement in an area from developing independently at full speed.
In practice, this means if you are in a vassal node, your progression may be restricted based on the level of your parent node. For example, a Village (stage 3) that is vassaled under a Town (stage 4) will not advance beyond certain stages unless the parent node allows or enables it through sieges and dynamic world events.
Most players will encounter vassal nodes when exploring regions dominated by larger settlements. These smaller nodes are often limited in what they can construct, what quests they can host, and which services are available to their citizens.
How Do Vassal Networks Work?
Vassal networks are hierarchical. They form a “family tree” of settlements, showing relationships from the sovereign node down to its dependent vassals. According to the latest design changes for Alpha-2 phase-3, the structure works like this:
City (Stage 5): Can control up to two Towns (Stage 4)
Town (Stage 4): Can control one Village (Stage 3)
Village (Stage 3): Can control one Encampment (Stage 2) or lower
Previously, the network was slightly more complex, with a Metropolis owning multiple Cities and their dependent nodes. The new model simplifies the hierarchy, making it more symmetrical and easier for players to understand at a glance.
In general, most players find this easier to visualize on the node summary page or in the map UI. Hovering over a node will show you the network from the sovereign down to all dependent settlements. This helps players quickly identify which nodes are part of the same political and economic network, and which areas might be contested in future sieges.
Why Does Vassalship Matter?
Vassalship serves several purposes in gameplay:
World Regulation: By locking certain settlements under higher-level nodes, the game prevents the world from being fully active everywhere. This ensures that some areas remain contested or underdeveloped, which is vital for dynamic world events.
Strategic Opportunities: If you want to influence a region, understanding which nodes are vassaled is essential. Taking control of a parent node can allow you to indirectly control multiple smaller settlements underneath it.
Siege and Advancement: Nodes progress when conditions are met, and vassal nodes can only advance when their parent nodes allow it. If a Village is destroyed in a siege, dependent settlements like Encampments may also be destroyed. This adds a layer of strategy to large-scale conflicts, giving players control over entire chains of settlements.
Most players who focus on PvP or political strategy find this particularly engaging. It’s not just about holding one location; it’s about managing a network of interdependent nodes.
How Does This Affect Daily Gameplay?
For everyday players, vassalship affects how you interact with settlements:
Resource Gathering: Some resources or crafting opportunities may only be available at parent nodes, so players in vassal settlements often travel to their parent’s location to access these benefits.
Quests and Services: Not all quests or city services are available in vassal nodes. For example, banks, crafting stations, and trade hubs are more likely in parent nodes.
Travel and Influence: Vassal settlements tend to be quieter and may have fewer guards, making them useful for stealthy operations or staging points for sieges.
Most players quickly learn to plan their routes and activities based on the node hierarchy. Understanding which settlements are vassaled can help you decide where to set up crafting, trading, or combat hubs. Some players even use vassal networks to maximize their influence across multiple nodes simultaneously.
How Do Vassal Settlements Interact With Sieges?
Sieges are central to node progression in AoC. If a parent node is attacked and falls, the status of its vassals can change dramatically. In most cases, when a Village (stage 3) is destroyed, its dependent Encampments are also removed or reduced.
This mechanic encourages strategic planning, as conquering a parent node can provide indirect control over multiple vassals. In practice, organized groups or guilds often coordinate attacks to disrupt the hierarchy and open up opportunities for new settlements to rise.
Additionally, the destruction or advancement of nodes affects world state. The dynamic progression system means that players directly influence which areas are thriving, which are contested, and which remain underdeveloped.
Tips for Players in Vassal Settlements
Know Your Parent Node: Most players underestimate the importance of understanding who controls their vassal node. The node summary page and map UI make it easy to see your parent and sovereign nodes.
Plan Around Restrictions: Vassal settlements may have limits on what they can build or upgrade. Knowing these restrictions helps you focus on activities that are feasible in your location.
Engage Strategically: Whether you want to advance your settlement or participate in sieges, always consider the broader network. Supporting or attacking a parent node can have ripple effects across multiple settlements.
Maximize Resource Efficiency: Since some resources may be limited in vassal settlements, players often combine trips to parent nodes or allied nodes. It’s also a good practice to coordinate with guilds or friends to make these trips productive.
Stay Aware of Dynamic Events: Node sieges and world events can change the status of vassal settlements quickly. Most experienced players track the network and prepare for potential changes, like new nodes opening up for advancement.
For players looking to maximize their progression or support their network, you may find it useful to buy AoC gold from a trusted site like U4N, which can help with faster gearing or resource acquisition in vassal and parent nodes alike.
Common Misconceptions About Vassal Nodes
Some new players assume that vassal settlements are permanently limited. In practice, they are dynamic. Vassal nodes can advance if parent nodes fall, are destroyed in sieges, or allow their vassals to progress.
Another misconception is that vassalship limits player freedom. While some restrictions exist, most players quickly adapt by leveraging parent nodes for resources and services. In fact, understanding vassal networks often gives players a strategic edge in both PvE and PvP gameplay.
Vassal settlements are a core part of Ashes of Creation’s dynamic world. They create strategic depth, regulate progression, and tie into the larger ecosystem of node sieges and world events. For players, understanding these networks is key to planning their activities, advancing their settlements, and influencing regional power dynamics.
By learning how parent and child nodes interact, you can position yourself to take advantage of opportunities that arise in dynamic gameplay, participate effectively in sieges, and maximize the influence of your character or guild. Most importantly, keeping an eye on the vassal network will help you navigate the ever-changing world of Ashes of Creation with confidence and strategy.
