What Is the Noisemaker Door Glitch?
The Noisemaker is a common deployable gadget in Arc Raiders. It’s basically a proximity alarm: when an enemy raider enters its 8-meter detection radius, it emits a sound to alert you. The glitch occurs when you deploy a Noisemaker near certain doors. In some cases, the door’s hitbox or interaction logic interferes with the Noisemaker, causing it to either:
Fail to trigger when raiders pass through, or
Trigger repeatedly without a raider present, creating constant noise.
In practice, this usually happens on tightly designed mission maps where doors are narrow and AI pathing is slightly off. Players often notice this when defending high-value objectives or trying to funnel enemies.
Why Does This Happen?
The glitch isn’t a mystery once you understand the mechanics:
Noisemakers detect colliders, not “raiders” directly. If a door blocks the detection in a certain way, the Noisemaker might think the raider hasn’t entered its area.
AI pathing quirks can make enemies “slide” along doorways or teleport slightly to avoid collisions. That movement can either prevent detection or cause the sensor to re-trigger rapidly.
Door animation timing matters. Doors in Arc Raiders often have a few frames where they’re considered “closed” even if visually open. If you place a Noisemaker right on this boundary, it can glitch out.
From what I’ve seen, this isn’t universal—some doors work fine. It’s map-specific and sometimes even position-specific.
How to Reproduce It Consistently
If you want to see the glitch for testing or just to understand its mechanics:
Place a Noisemaker directly in front of a door that opens inward.
Wait for an enemy to approach the door.
Observe the Noisemaker either not triggering or triggering multiple times before the enemy passes.
Adjust placement slightly (1–2 meters left or right), and you’ll often see it work as intended again.
Many players have done this to “farm” alerts or to stress-test AI behavior. The glitch is subtle and usually requires careful observation of AI and gadget interactions.
Does It Affect Gameplay Significantly?
Here’s the practical takeaway:
Minor annoyance: In most missions, it won’t break your game. You might hear a constant alert, but you can ignore it.
Tactical exploitation: Some players use it to slow AI down or trick teammates into thinking enemies are nearby. It’s inconsistent, though. You can’t reliably count on it to clear objectives or farm resources.
Resource planning: If you deploy a Noisemaker that glitches, it still counts toward your inventory use. In some modes, wasting gadgets can be costly if you’re low on supplies.
This is important if you’re thinking of investing in multiple Noisemakers or considering selling arc raiders items for cash—knowing which placements are reliable matters.
How Experienced Players Handle It
From my experience, the smartest approach is prevention rather than trying to exploit the glitch:
Avoid doorways: Place Noisemakers slightly to the side or in wider hallways.
Check enemy paths: Watch how AI moves. If they tend to clip doorways, move the gadget elsewhere.
Use stacked gadgets carefully: Noisemakers stack up to three. If one glitches, the others can still cover adjacent areas.
Recycling & salvaging: If a Noisemaker has been misused, you can recover its core component. This keeps your resources efficient.
The idea is to deploy them where detection is reliable. Experienced players treat Noisemakers like sensors, not traps. They’re helpful for awareness, but you shouldn’t rely on them as a major combat tool.
Common Questions from the Community
Q: Can this glitch alert you to enemies early?
A: Sometimes, yes. If the glitch triggers repeatedly, you might notice a “phantom” alert before an enemy arrives. But it’s unpredictable, so don’t count on it for timing attacks.
Q: Can multiple Noisemakers cause compounded glitches?
A: Absolutely. If you stack three on or near the same door, the glitch can multiply, creating nearly continuous sound alerts. This is mostly a nuisance, though it can confuse other players in co-op missions.
Q: Will the developers fix this?
A: Probably eventually. It’s a minor issue compared to bigger AI and mission bugs, but if enough players report it, the detection logic around doors may get tweaked.
The glitch is real but situational: It only appears with specific doors and AI behavior.
Placement matters more than quantity: One well-placed Noisemaker is better than three glitching ones.
You can recover resources: Use recycling and salvaging to avoid losing gadgets permanently.
Plan deployment with AI paths in mind: This reduces false alarms and wasted gadgets.
Understanding this glitch can make your missions smoother. It’s not game-breaking, but knowing how your Noisemakers interact with doors can give you a small edge in tactical setups.
Arc Raiders Muzzle Brake 2 Blueprint Guide
Arc Raiders Noisemaker Door Glitch: What Players Need to Know
- WhisperFlower
- Minivan
