RSVSR How to Get Red Coral Jewelry in Arc Raiders
Rodrigo
Red Coral Jewelry is one of those drops in Arc Raiders that can turn a rough run into a decent one fast. You might open ten drawers and find junk, then the next little cabinet gives you the piece you've been chasing all evening. It sells for 5,000 Coins, which is no small thing when you're trying to keep weapons, shields, and tools in shape. It also matters for progression, since you'll need three pieces for Phase 5 of the Aviam Alarm Project. That's why players who normally ignore small containers are suddenly slowing down and checking every corner ARC Raiders Coins. If you're planning your runs around valuable ARC Raiders Items, this is one of the pieces worth learning properly.
Where Red Coral Jewelry Usually Turns Up
The best thing you can do is stop treating every building the same. Red Coral Jewelry tends to show up in places that feel lived in or used for day-to-day work. Apartments, hotel rooms, offices, reception areas, and old admin spaces are the sort of places you want. Don't just scan the floor and leave. Open drawers. Check bedside tables. Look inside shelves, cabinets, and little storage units that other players often skip. It's not glamorous looting, and yeah, it can feel slow, but that's usually how you beat the players who only rush the big shiny landmarks.
Good Routes on Dam Battlegrounds and Blue Gate
On Dam Battlegrounds, Pale Apartment and Ruby Residence are easy places to start because they fit the loot profile well. Pattern House is also worth a sweep, especially if the area hasn't already been picked clean. Research and Administration buildings can be a bit tense, but they're useful if you're willing to move room by room. At Blue Gate, the Village and Raider's Refuge are solid choices. I'd also check the Abandoned Housing Project and Ruined Homestead when you're passing through. A lot of squads skip them because they don't look exciting from the outside, which is exactly why they can pay off.
Buried City and Spaceport Spots Worth Checking
Buried City has some of the better spots if you're patient. Grandioso Apartments and Piazza Rosa should be high on your list, since both have the kind of indoor clutter that can hide jewelry. The Library can be hit or miss, but it's still worth a careful look if you're already nearby. Space Travel and Piazza Arbusto are decent side stops too. If you're running Spaceport, focus on the Arrival and Departure buildings first. Control Tower A6 can be risky, but it has the right loot feel. North Trench Tower and South Trench Tower are also worth checking when the route is safe enough.
How to Make the Hunt Less Painful
Don't build a run around one single room. That's how you get frustrated. Pick a route with several residential or commercial interiors, loot them clean, then leave before the whole map turns into a mess. If you find one Red Coral Jewelry, bank it when you can rather than getting greedy. Three pieces for the Aviam Alarm Project sounds simple, but bad raids can wipe out a night's progress ARC Raiders Items. As a professional platform for buying game currency or items, RSVSR is built for players who want a more convenient way to prepare, and you can buy rsvsr ARC Raiders Items to smooth out the grind when luck isn't helping. Keep your route tight, listen for movement, and never ignore the boring little drawers.
