Where to Find Arc Raiders Blueprints and Craft Medium Gun Parts
WhisperFlower
If you’re playing Arc Raiders, one of the items you’ll eventually encounter is the Medium Gun Parts Blueprint. In general, this blueprint is essential if you want to craft Medium Gun Parts, which are used in a variety of weapons. Below, I’ll explain how it works, how to get it, and what most players do in practice to use it efficiently.
What is the Medium Gun Parts Blueprint?
In simple terms, a blueprint in Arc Raiders is an item that allows you to craft a specific piece of gear. The Medium Gun Parts Blueprint lets you craft Medium Gun Parts. These parts are used in assembling or upgrading weapons that require medium-sized components.
Most players treat blueprints as a long-term investment. Even if you don’t need Medium Gun Parts immediately, keeping the blueprint can save time later when you want to craft weapons efficiently.
Where to Find the Medium Gun Parts Blueprint
The blueprint itself can usually be obtained through looting, specifically from the topside areas. In general, the loot drops in Arc Raiders follow a semi-random pattern, so you might need to search a few different locations before you find this particular blueprint.
Most players recommend prioritizing areas that are densely populated with loot crates or enemy spawns, as these zones tend to have a higher chance of dropping blueprints, including the Medium Gun Parts Blueprint.
How to Craft Medium Gun Parts
Once you have the blueprint, you’ll need specific materials to craft Medium Gun Parts. In practice, most players gather these materials before crafting to avoid multiple trips.
Required Materials:
Refiner 2 – This is usually a crafting station or level requirement in your base. Make sure your base has this station ready.
4x Simple Gun Parts – These are typically found in loot crates or dismantled from other weapons.
To craft the Medium Gun Parts, you’ll need to interact with the Refiner 2 station while having the materials in your inventory. The crafting process is straightforward and usually takes a few seconds.
Most players find it helpful to craft multiple Medium Gun Parts at once if they have enough Simple Gun Parts, as this reduces the number of crafting sessions you need to perform.
Using Medium Gun Parts
Medium Gun Parts are generally used for weapon upgrades or repairs. In practice, players often stockpile these parts because certain weapons can require several Medium Gun Parts at once.
For example, if you’re trying to build or maintain a mid-tier weapon, you might need 2–4 Medium Gun Parts per weapon. Planning ahead and crafting in batches can save a lot of time during missions, especially in higher difficulty zones where materials are scarce.
Common Player Strategies
In general, players approach blueprints like the Medium Gun Parts Blueprint in a few ways:
Loot Focus: Some players prioritize searching areas known for high blueprint drops. This helps them build a collection of crafting options early in the game.
Material Stockpiling: Before crafting, most players gather all necessary resources so they can craft multiple items in one session.
Blueprint Sharing: If playing in a team, it’s common for players to divide responsibilities, with some gathering blueprints and others focusing on collecting crafting materials.
Most players also recommend checking the in-game marketplace or in-game trade systems if you are low on time, though the real value comes from understanding where and how to farm the blueprint effectively. Searching online guides can sometimes help locate the most reliable spawn points.
It’s also worth noting that some players look for ways to arc raiders blueprints buy options when they want to accelerate their crafting progress. While this can save time, relying on in-game farming often provides better long-term resource management.
Tips for Efficient Crafting
Batch Crafting: Craft as many Medium Gun Parts as your materials allow to minimize trips to the Refiner 2.
Plan Resource Use: Simple Gun Parts are used for multiple recipes. Don’t craft them all into Medium Gun Parts unless you have a clear need.
Team Coordination: If playing with a squad, assign roles: some players focus on looting blueprints, others on gathering crafting materials.
Blueprint Tracking: Keep a small inventory or checklist of blueprints you have versus blueprints you need. This helps prevent unnecessary farming.
The Medium Gun Parts Blueprint is an important item for crafting mid-tier weapons in Arc Raiders. Most players find it by looting topside areas and then using a Refiner 2 with 4 Simple Gun Parts to craft Medium Gun Parts. In practice, efficient crafting involves planning your materials, batch crafting, and coordinating with your team.
Remember, while there are ways to shortcut the process through buying or trading, most experienced players focus on understanding blueprint locations, crafting requirements, and material management to stay self-sufficient.
