Arc Raiders is full of various mechanics and systems that players must understand to thrive in its world. One of the key features for crafting advanced equipment is the Blueprint system. One of the more useful items in the game is the Silencer I, and in this guide, we'll cover everything you need to know about how to get it, craft it, and use it effectively in your journey.
What Is the Silencer I Blueprint?
The Silencer I Blueprint is a crafting blueprint in Arc Raiders that allows players to craft a Silencer I. This is an essential item for those who prefer a stealthier approach to combat. The Silencer I helps reduce the noise made by your weapon, allowing you to eliminate enemies without drawing too much attention from nearby threats.
Most players find this useful when they want to stay under the radar, especially in areas filled with enemy raids or hostile creatures. The Silencer I doesn't make your shots completely silent, but it does lower the noise level significantly, making it a great tool for ambushes or when sneaking around enemies.
Where Can I Find the Silencer I Blueprint?
The Silencer I Blueprint is not something you can purchase in shops or find in easy-to-reach areas. It is usually found by looting in the topside areas. These are the regions that are generally more exposed to dangers and can be harder to navigate due to their open spaces and high enemy presence.
Most players will find themselves exploring these areas carefully to avoid getting caught by aggressive enemies. It's a good idea to have a solid strategy in place before heading into the topside, as these locations can be tricky. Make sure you're prepared with enough healing items and equipment to get through unscathed.
Can I Sell the Silencer I Blueprint?
If you happen to find an extra Silencer I Blueprint, you may wonder if it's worth anything. While blueprints can’t typically be traded directly with NPCs, you can sell ARC Raiders items for cash on U4N if you're looking to make some in-game currency. This gives you the option to sell the blueprint to other players if you don't need it for crafting, but bear in mind that it's always best to hold onto these items if you’re aiming to craft a variety of equipment.
How Do I Craft the Silencer I Using the Blueprint?
Once you've acquired the Silencer I Blueprint, you'll need a few materials to craft the item. Crafting in Arc Raiders requires careful attention to detail, as using the wrong materials or not having the right skills can leave you stuck.
Materials Needed for Crafting
To craft a Silencer I, you will need the following materials:
Gunsmith 2 (skill)
2x Mechanical Components
4x Wires
Gunsmith 2: This is a crafting skill that you’ll need to have at level 2. The Gunsmith skill tree is all about crafting and modifying firearms. If you don’t have Gunsmith 2 unlocked yet, you'll need to level up in this tree before you can craft the Silencer I.
Mechanical Components: These can be gathered by looting certain areas or breaking down other mechanical equipment. They're relatively common, but you may need to explore specific regions where they are more abundant.
Wires: Wires are another common crafting material, and you can find them in most tech-heavy environments. Like Mechanical Components, these can be looted from various sources or broken down from other items.
How to Craft the Silencer I
Once you've gathered the required materials and unlocked the Gunsmith 2 skill, you can craft the Silencer I at any crafting station. This process is straightforward, but always double-check that you have everything before starting. You’ll be able to attach the Silencer I to compatible firearms once you’ve crafted it.
How Effective Is the Silencer I in Gameplay?
The Silencer I in Arc Raiders is designed to reduce the noise made by your weapon, which can be helpful in certain situations. However, it’s important to keep in mind that it doesn’t completely eliminate sound. You’ll still need to be careful, as enemies nearby can still detect you if they’re close enough or if you’re using a loud weapon.
Most players use it on rifles and pistols that are capable of attaching the silencer. However, it’s not a necessity for every player. It’s most useful in areas where stealth is crucial, such as during ambushes or when exploring places with large groups of enemies. For high-action players who engage in constant gunfights, a silencer might not be as useful.
In general, the Silencer I is more for players who want to avoid being overwhelmed or who prefer tactical stealth approaches. It’s a good tool for the job, but it’s not the be-all and end-all. You still need to play strategically and make good use of other combat techniques.
How Much Does the Silencer I Blueprint Cost?
The Silencer I Blueprint is valued at 5000 in-game currency. This is a reasonable price considering the crafting materials and the usefulness of the silencer itself. If you’re a player who enjoys crafting, it’s worth obtaining the blueprint and making the silencer yourself rather than buying it from other players or NPCs.
If you don’t want to craft it yourself, you can always check the player markets to see if someone is selling the silencer or blueprint. However, most players recommend crafting it on your own as it’s usually cheaper and gives you more control over your gear loadout.
Is the Silencer I Worth Crafting?
Whether or not the Silencer I is worth crafting depends on your playstyle. If you prefer to avoid direct combat and favor stealthy takedowns, then yes, it’s an invaluable item. On the other hand, if you’re the type of player who enjoys loud and chaotic gunfights, the Silencer I might not be a top priority for you.
In general, players who enjoy solo play or who work as part of a team to infiltrate areas quietly will benefit most from the silencer. If you don’t mind being loud and aggressive, it may be better to invest in other upgrades for your weapons instead.
The Silencer I Blueprint is a useful crafting item in Arc Raiders that can make your gameplay experience smoother if you prefer stealth. While it’s not necessary for everyone, it’s a good tool for players who like to avoid drawing attention. Finding the blueprint can be challenging, but once you have it, crafting the silencer is fairly easy as long as you have the right materials and skill.
If you're new to the game, it's worth learning how to craft items like the Silencer I early on, as it can help you adapt to different playstyles. And if you ever find yourself with extra items you don't need, remember that you can sell ARC Raiders items for cash on U4N, giving you some extra in-game currency.
Arc Raiders Silencer I Blueprint Guide: Where to Find and How to Craft
- WhisperFlower
