U4GM Why This Cheap Blood Boil Warlock Wins in D2R S13
El-bilsmärket Tesla!
CosmicFlare
Most people roll the Season 13 Warlock and immediately start daydreaming about pricey rune setups, but I went the other way and built around Blood Boil with whatever I could scrape together, plus a quick look at cheapest diablo 2 resurrected items to sanity-check what "budget" really means. Two weeks later, I'm still playing it because it feels different. It's not that constant teleport-and-delete rhythm. You're setting up kills, reading packs, and letting your own army do the dirty work.
Blood Boil isn't a fire spell, it's a trigger
A lot of players misread Blood Boil as "cast spell, deal damage." That's not the deal. Blood Boil is a detonation switch. Your demons are the payload, not your wand. Pop the skill and every demon you've got out turns into a walking blast zone, splitting Fire and Physical damage. That split matters in Hell, where you'll hit immunities and weird resist combos nonstop. Placement matters too. If your demons are off chewing on a straggler, your "nuke" fizzles. If they're stacked on a choke, you'll watch a whole screen fold.
Skill points that actually pull their weight
Start simple: max Blood Boil first. After that, don't get baited into dumping everything into Demonic Mastery early. You're mainly chasing the breakpoint for three demons, and you can often reach it around level 10 once your gear and charms kick in. The spare points feel way better in Blood Oath and Engorge for synergy. Also, Bind Demon is the sneaky power move. If you can bind something nasty in the River of Flame—Hephasto is the classic target—and it rolls Cursed or Conviction, it's like you rented an Infinity aura without paying for it. Suddenly "unbreakable" packs aren't so smug.
Budget gear, but you still need casting speed
The gear list is almost funny: Leaf staff, Stealth, Lore, whatever res boots you can find. The one thing I won't compromise on is hitting 75% FCR. Under that, Blood Boil feels sluggish, and mobs just stroll out of your blast radius like they've got an appointment. Patch it with a couple of FCR rings, a decent Warlock amulet, or even a swap piece if you have to. For the merc, Act 2 Holy Freeze is the comfy pick, and Insight is non-negotiable because you'll be casting constantly and mana burn packs are everywhere.
How it performs and why I'd still recommend it
It's not a speedrun build, and that's fine. Around the high 70s, I was clearing Chaos Sanctuary in the mid-teens for minutes, and it felt consistent, not sweaty. The Secret Cow Level is where it really clicks, because density turns "one boom" into overlapping chains that keep rolling. If you do want to smooth out the rough edges—missing FCR, weak resists, or a key charm—this is exactly the kind of build where small upgrades matter, and grabbing a couple pieces through U4GM can save you hours of stalled farming without turning the whole thing into a high-rune flex.
