Byta bromslampa Dodge journey
broglin
Jag har problem att se hur jag skall få bort själva armaturen "vänster bak där bakljus/bromsljus sitter...
skulle någon kunna berätta hur man gör?
tack på förhand
//Robert
Re: Byta bromslampa Dodge journey
Kolla in denna videon jag hittade:
http://www.carcarekiosk.com/video/2010_ ... rake_light" onclick="window.open(this.href);return false;
Såhär står det i manualen:
1. Open the liftgate.
2. Remove the two fasteners from the inboard side of the
taillamp housing.
3. Carefully insert a trim stick (plastic flat-blade tool)
between the body panel and the outboard side of the
taillamp housing with one hand and grasp the flange on
the inboard side of the taillamp housing with the other
hand. Use the trim stick and hand pressure together to
disengage the taillamp housing from the vehicle.
Verkar vara ganska smidigt :)
