Beginner Guide to Driving the Evo 3 GSR in Forza Horizon 6
FrostStrikeX
The 1995 Mitsubishi Lancer Evolution III GSR is one of the best beginner-friendly cars in Forza Horizon 6. Even though it sits in B-Class, it feels surprisingly capable on almost every type of road. Whether you are driving through mountain passes, wet asphalt, or loose dirt trails, the Evo 3 stays stable and predictable in situations where many starter cars lose control.
A big reason players love this car is its AWD system. The Evo 3 gives you a huge amount of grip while still feeling lively enough to enjoy. For new players learning braking points, cornering lines, and throttle control, it is one of the safest cars to practice with without feeling slow or boring.
You can also unlock it relatively early as a hidden Treasure Car in the Takashiro region near the waterfall area, making it an excellent first serious build for career progression.
Why the Evo 3 Is So Good for Beginners
The Evo 3 is forgiving in ways that many classic rally-inspired cars are not. It recovers from mistakes quickly, rotates nicely through corners, and accelerates hard out of tight turns thanks to the AWD drivetrain.
Instead of focusing on top speed, this car rewards momentum driving. If you keep smooth racing lines and avoid overdriving corners, the Evo becomes incredibly fast for its class.
Some of its biggest strengths include:
Strong traction on both road and dirt
Stable handling during high-speed cornering
Fast acceleration out of slow turns
Lightweight feel compared to heavier AWD cars
Easy recovery when the rear starts sliding
For beginners, this means fewer spins, fewer crashes into guardrails, and more confidence while learning the map.
Recommended Difficulty Settings
Before modifying the car, it helps to set up the driving assists correctly. The Evo 3 already has natural grip, so some assists can actually make the car feel slower or less responsive.
Steering
Set steering to Standard.
This gives controller players smoother counter-steering behavior and makes the car easier to catch during small slides. Simulation steering can feel too twitchy for newer players.
Traction Control and Stability Control
Turn both off.
Normally beginners rely on these assists, but the Evo 3 does not really need them. The AWD system already provides enough grip. Keeping traction control enabled can reduce acceleration when exiting corners, especially on dirt roads.
ABS
Keep ABS on.
The stock brakes on the Evo 3 are not great. ABS helps prevent wheel lockups when braking hard into hairpins or downhill corners.
Driving Line
Use Full Driving Line or Corners Only.
The Evo is perfect for learning braking zones. Watching the line change from blue to red teaches you when to slow down before entering corners.
Learning the Evo 3 Driving Style
The biggest mistake new players make is treating the Evo like a high-horsepower highway car. It is much faster when driven smoothly and aggressively through corners rather than relying on raw speed.
Brake Early
The Evo dislikes heavy braking while turning.
If you slam the brakes mid-corner, the car starts pushing wide into understeer. Instead, brake in a straight line before the corner, release the brakes, and then turn into the apex cleanly.
This single habit instantly makes the car easier to control.
Slow In, Fast Out
The Evo 3 shines on corner exits.
Enter the corner slightly slower than you think you need to, then once the nose points toward the exit, apply full throttle confidently. The AWD system pulls the car forward aggressively and helps stabilize the chassis.
You will often exit corners faster than players using more powerful cars.
Using Small Slides on Dirt Roads
One of the best parts of the Evo is how naturally it handles dirt surfaces.
You do not need dramatic handbrake drifts. Instead:
Lift off the throttle briefly
Turn sharply into the corner
Let the rear rotate slightly
Reapply throttle hard
The AWD system immediately pulls the car straight again.
This creates fast, controlled micro-drifts that work extremely well on rally stages and mountain roads.
Best Beginner Upgrades
A lot of players ruin the Evo by immediately forcing it into S1 or S2 class with massive horsepower upgrades. The car loses its balance when pushed too far.
The sweet spot is staying near the top of B-Class around PI 700.
Weight Reduction
This should be one of your first upgrades.
The Evo already feels light, but Race Weight Reduction makes the car even more responsive during braking and direction changes.
Better Brakes
The stock brakes are the weakest part of the car.
Sport or Race Brakes make a huge difference, especially on technical mountain routes with repeated heavy braking zones.
Tire Choice
Keep Stock or Street tires.
Many beginners waste too many performance points on expensive Race or Rally tires. The Evo already has excellent grip from AWD, so those upgrades are not necessary early on.
Using lighter tire upgrades leaves room for better balance elsewhere.
Race Differential
A Race Differential completely changes how the car rotates.
A good beginner setup is:
35% Front
65% Rear
This gives the Evo a more playful feeling during corner entry while still keeping the safety of AWD traction.
The car starts feeling more alive without becoming difficult to control.
Best Places to Practice
The Evo 3 performs best on technical roads with lots of direction changes.
Some ideal practice locations include:
Mountain touge roads
Wet forest roads
Dirt rally routes
Medium-speed canyon highways
Mixed asphalt and gravel sections
The car especially shines in downhill sections where braking stability and corner exits matter more than top speed.
Common Beginner Mistakes
Over-Upgrading the Engine
Too much horsepower destroys the balance that makes the Evo fun.
A lighter, well-balanced B-Class setup is often faster than a badly tuned S1 build on technical roads.
Using the Handbrake Too Often
The Evo naturally rotates well enough without relying on aggressive drifting.
Most corners are faster using smooth throttle lifts instead of handbrake entries.
Braking Too Late
Because the AWD grip feels so strong, beginners often enter corners too fast.
The Evo rewards discipline. Smooth entries lead to much faster exits.
The 1995 Mitsubishi Lancer Evolution III GSR is one of the best starter cars in Forza Horizon 6 because it teaches good driving habits while still being genuinely competitive. It has enough grip to forgive mistakes, enough agility to stay exciting, and enough tuning potential to remain useful long after the early game.
For beginners learning rally driving, mountain racing, or AWD handling, the Evo 3 is one of the easiest cars to trust. Once you understand how to carry momentum through corners and use the AWD traction properly, the car becomes incredibly satisfying to drive on almost every road in the game.
