In Helldivers 2, Warbonds are one of the main progression systems that let players unlock new weapons, armor, and cosmetics. Unlike standard upgrades, Warbonds require a steady grind of Medals and Super Credits, which makes farming routes especially valuable. If you’re looking to maximize your time on the battlefield and progress through Warbonds efficiently, here are the best farming routes and strategies to keep in mind.
Focus on Short, High-Yield Missions
The most efficient way to farm Warbonds is to choose operations that offer multiple quick missions rather than long, drawn-out ones. Missions on lower difficulties often give a better return on time since you can finish them faster while still collecting a decent amount of Medals and samples. Bug-infested planets are usually the easiest for quick clears, especially if you’re running solo or with a smaller squad.
Prioritize Secondary Objectives
While the main objective brings in mission rewards, secondary objectives often yield Medals or additional resources. Always keep an eye on optional tasks such as destroying nests, rescuing civilians, or activating comms arrays. These extras don’t take much time and can significantly boost your farming efficiency.
Sample Runs for Extra Resources
Samples are a key part of progression and are often scattered across the map. Choosing missions where you know the sample spawn points can give you an advantage, especially since higher-tier samples contribute to better research unlocks. Over time, this adds more value to your farming routes and complements your Warbond progression.
Squad Coordination for Faster Runs
If you’re farming with a squad, consider dividing roles. One player can focus on objectives while others prioritize gathering samples or clearing enemies. This reduces wasted time and increases the efficiency of each farming run. Coordinated squads are also more capable of handling higher difficulties, which means more rewards per mission.
Balancing Farming with Purchases
Some players prefer to speed up their Warbond unlocks by supplementing farming with in-game purchases. For example, if you decide to buy Helldivers 2 Super Credits, you can progress through Warbonds without relying solely on grind-heavy farming. Similarly, choosing to buy Helldivers 2 Medals provides a shortcut to unlock specific gear or weapons faster. While farming is the main method of progression, combining both approaches gives you flexibility depending on how much time you want to invest.
Recommended Routes
Low-Difficulty Bug Planets – Great for solo farming due to fewer heavy enemies and plenty of secondary objectives.
Medium-Difficulty Bot Missions – Bots often drop useful samples, and missions are quick if you stick to smaller maps.
Operation Chains – Running through full operation chains increases your Medal count and offers more consistent Super Credit rewards.
Farming Warbonds in Helldivers 2 is all about efficiency. Whether you prefer quick missions against bugs, coordinated squad runs, or full operation chains, the key is to balance speed with reward. Over time, you’ll find routes that fit your playstyle best. And if you ever feel the grind is slowing you down, having the option to buy Helldivers 2 Super Credits or buy Helldivers 2 Medals ensures you never fall behind on unlocking the latest Warbond gear.
Best Farming Routes for Helldivers 2 Warbonds
- FrostStrikeX
