If you’re the kind of player who loves digging through every corner of Appalachia for side stories, the Dirty Laundry holotape chain is a fun little scavenger hunt. These tapes tell a short but interesting drama that unfolds across multiple locations, and tracking down all 15 can feel surprisingly satisfying. Below is a simple, player-friendly guide to help you grab every tape without getting lost. I’ll also share a few tips I learned after doing this run more than once, because some of these spots can be sneaky.
What You Need to Know Before You Start
The Dirty Laundry holotapes aren’t tied to a particular quest, so you can collect them in any order. They mostly appear in small camps, abandoned homes, and quiet corners of the map. A few are inside higher-level areas, but nothing too dangerous if you move carefully.
You don’t need special gear, although having a bit of space in your inventory is always good. I tend to keep an eye on my stash because I pick up a ton of random Fallout 76 items along the way. Some of these places are great for grabbing junk or materials.
Holotape 1: Aaron’s Cabin
You’ll find the first tape inside a small cabin in the Forest region. It’s usually sitting on a desk or shelf near the main room. Watch for a possible random spawn enemy outside, usually low level.
Holotape 2: Riverside Manor Grounds
Head to the exterior of Riverside Manor. There’s a ruined shed on the side of the property where the tape sits on a crate. If you’ve already done quests here, you know the area well.
Holotape 3: North Kanawha Lookout
Climb the tower, and you’ll find the tape near the sleeping bag at the top. This is also a great spot for grabbing wood and checking for small loot containers.
Holotape 4: Tygart Water Treatment
Enter the main office building. Look for a table near the control panels. This area isn’t too hostile, but watch out for feral ghouls.
Holotape 5: Summersville Lake
Look for a small riverside picnic area. The tape is usually on one of the benches. The view here is surprisingly peaceful considering everything else happening in Appalachia.
Holotape 6: Gauley Mine Exit
Instead of entering the mine, go to the exit located up the hill. The tape is placed near a lantern on a table. This spot is easy to miss unless you’ve explored Gauley Mine a lot.
Holotape 7: Pioneer Scout Camp
Check the mess hall building. The tape rests near a tray on one of the long tables. While you’re here, it’s a good time to farm adhesive if you search through the kitchen area.
Holotape 8: Drop Site C2
This one is tucked inside an Enclave facility structure. It’s out in the open but can have higher-level automated enemies. Move slowly, and you’ll be fine.
Holotape 9: The General’s Steakhouse
Find the kitchen area, and the tape will be on a prep counter. The steakhouse is a nice indoor spot if you need a breather from outdoor mobs.
Holotape 10: Lake Reynolds
There’s a destroyed dock leading into the water. The tape sits on one of the broken boards. A couple of Mirelurks sometimes patrol here.
Holotape 11: Pleasant Valley Station
Inside the train station, you’ll find the tape near the ticket counter. This place is also a decent trading stop when you need to unload gear.
Holotape 12: Hemlock Holes
Go toward the driving range. The holotape is placed at a practice booth. Mutants may spawn here, so stay alert.
Holotape 13: Sunnytop Station
Check the waiting room table. This is a pretty straightforward pickup, and the station often has a vendor bot if you need to sell excess loot.
Holotape 14: Middle Mountain Cabins
Go into the left cabin. The tape is usually beside a metal bedframe. You may run into a Yao Guai nearby, so avoid rushing in blindly.
Holotape 15: Whitespring Service Area
This final tape sits inside one of the garage sections. While you’re in Whitespring, it’s often a good moment to check vendors or repair gear. I once stopped here after a long run and was relieved to find exactly what I needed among some Fallout 76 items for sale PC, especially when I didn’t want to farm materials again.
Extra Player Tips
If you're running the entire route in one go, I suggest starting in the Forest and slowly looping north. This makes the hunt feel more like a road trip through the early-mid game zones. Some players like jumping around with fast travel, but walking the long way lets you enjoy more random encounters and loot. I’ve found a couple of uniquely modded weapons this way, plus it helps me justify checking a trusted marketplace like U4GM whenever I need something specific without grinding endlessly.
Most of the Dirty Laundry tapes are located in small, quiet buildings, so they’re great stops when you want a chill exploration session. Even if the story behind the tapes isn’t massive, completing the chain feels like uncovering a hidden slice of wasteland life, and that’s part of what makes Fallout 76 fun.
Hidden Features: Fallout 76: Top 4 CAMP Builds of 2025
Fallout 76 Dirty Laundry Holotape 1–15 Locations
- TheVioletVagrant
